Drawing lines
gary
Drawing lines
Post by gary » Thu Aug 08, 2019 7:17 am
I have 2 layers. An image is on layer 0. I draw an outline of the image on layer 1.
If I make layer 0 hidden, and layer 1 active, I cannot draw a line on layer 1. I get a message telling me to check block recursions or hidden layers or blocks.
What must I do to be able to turn a layer off and draw lines on an active layer?
Re: Drawing lines
Post by Husky » Thu Aug 08, 2019 7:35 am
If you get this message that means you are trying to draw on an invisible, frozen or locked layer.
Make sure that layer 1 is visible, thaw, not locked and that it is the active layer. The active layer has a "Pen" visible in the Layer List.
Something like this: Layer "1. Object" is active, visible, thaw, unlocked ...
