Hatching
simonbolton
Hatching
Post by simonbolton » Fri Jun 14, 2019 3:07 pm
I am having a problem hatching. No problem when I draw a continuous line with same start and end or a rectangle outside of a drawing but when I try to do the same within a drawing, say a wall which I know to be a continuous line, then I get advise note in red saying
"loop not closed at point...' and there seems to be no way of connecting said loop. Where am I going wrong please.
Many thanks
Simon
Re: Hatching
Post by andrew » Fri Jun 14, 2019 3:10 pm
Please check for duplicate entities for example by selecting your entities and checking if the selection count in the status bar matches your expectations. You can also use Modify > Detection > Detect Duplicates.
If you cannot solve the problem, please attach or e-mail the drawing file.
