Set MAX line weight for "dwg2bmp"?
garciadelcastillo
Post by garciadelcastillo » Fri May 24, 2019 3:00 pm
Hi there,
Similar to the "-min-lineweight" options in "dwg2svg" and "dwg2bmp", is there a way to set MAX lineweight?
I am looking specifically at this feature for "dwg2bmp." Depending on the configuration of the CAD file, rasterization some times yields terrible results (see attachment).
Thanks!
Re: Set MAX line weight for "dwg2bmp"?
Post by andrew » Fri May 24, 2019 3:02 pm
No, there is currently no option to set the maximum line weight.
garciadelcastillo
Post by garciadelcastillo » Fri May 24, 2019 3:05 pm
Ok, thanks. Is there a formal way to submit a "feature request"? Is that here? https://qcad.org/rsforum/viewforum.php?f=31
Post by andrew » Fri May 24, 2019 3:06 pm
Please submit feature requests to our task tracker at:
https://qcad.org/bugtracker/
garciadelcastillo
Post by garciadelcastillo » Fri May 24, 2019 3:07 pm
Wonderful, thanks andrew! :)
