Adjusting opacity of solid fill?
wendi
Post by wendi » Sat Apr 13, 2019 6:54 pm
Qcad 3.21.2.0; Win10Pro64. Is it possible to vary the opacity of a solid fill? I'd like to lightly color an area of my drawing without blocking out what is under this color. Some of the entities are color filled themselves, so putting this desired light coloring on the bottom layer doesn't really do what I want. Thanks.
Re: Adjusting opacity of solid fill?
Post by Husky » Sat Apr 13, 2019 8:45 pm
No - not in the current version of QCAD.
Idea / Workaround?
You can control the opacity and size of an bitmap.
Create a bitmap in the desired color, load it in your drawing and adjust position, the size and the opacity as you need it.
wendi
Post by wendi » Mon Apr 15, 2019 8:50 am
Interesting idea. I'll play around with it. Thanks.
