Using version 3.22, my title bar is hidden so I can't resize, minimize etc.
I know there has got to be a setting for that, but I cant seem to find it in the view menu or application preferences.
help???
title bar is hidden
Re: title bar is hidden
Probably: Window > Fullscreen or Shift-Ctrl-F or F11, depends on your system (Windows, macOS, Linux).
Try to toggle the "Full screen" on your keyboard with the F11 key.
thanks....another thing I didn't know about windows!
@Andrew:
Our timing is very bad .....
@Husky:
Yes.. well, I usually only reply that quickly if the solution is obvious and short.
