insert a block
GeoffBlyth
insert a block
Post by GeoffBlyth » Tue Mar 05, 2019 7:29 am
I must be missing something
trying to insert a block into a drawing
I select the block, click insert and nothing happens
Is there more to this
new to this prog and a lot to learn
Re: insert a block
Post by Husky » Tue Mar 05, 2019 8:20 am
Hi GeoffBlyth - welcome to the QCAD forum.
The block should be visible at your mouse pointer. If not maybe your active layer is switched to invisible or frozen.
