dwg2bmp, dwg2pdf, dwg2svg: make layer visible
malomalo
Post by malomalo » Mon Feb 25, 2019 10:23 pm
I am using dwg2bmp and want to show all but one layer. In the file only the "RELEASE" layer is visible. I am removing the "RELEASE" layer with:
-layer='((?!(RELEASE)).)*'
However all the other layers are still not visible. Is there a way to make them visible by default?
Re: dwg2bmp, dwg2pdf, dwg2svg: make layer visible
Post by andrew » Tue Feb 26, 2019 11:26 am
Can you try with the latest snapshot version 3.21.3.19 available from your download link.
malomalo
Post by malomalo » Tue Feb 26, 2019 7:21 pm
I just check and I'm running QCAD version 3.21.3; also just downloaded the link again and the downloads are the exact same.
Post by andrew » Tue Feb 26, 2019 8:10 pm
Snapshot releases are not official releases but snapshots of the current development.
You can find snapshots on your download page under "Snapshots".
malomalo
Post by malomalo » Tue Feb 26, 2019 10:34 pm
Looks like that worked! Awesome, Thank you!
