angle print
jtbrooks
angle print
Post by jtbrooks » Sat Feb 23, 2019 11:33 am
how do I indicate the angles of a triangle, how to get them to print to a drawing
Re: angle print
Post by andrew » Sat Feb 23, 2019 12:50 pm
There are various tools to create line with a given angle (Draw > Line > Line from Angle, Draw > Line > Relative Angle, ...).
You can dimension angles using Dimension > Angular.
For more specific help, please post more information with your requirements, post a screenshot of your drawing (perhaps approximate), etc.
jtbrooks
Re: angle print
Post by jtbrooks » Sat Feb 23, 2019 11:54 pm
Thank you very much that is what i need to find. It was the help I wanted. :)
