ver.3.21.3pro. unable to exit QCAD
nationalalf
Post by nationalalf » Wed Jan 30, 2019 8:04 pm
I am unable to close the program. the minimised / maximised/close box ( top right hand corner are not visible ) also i do not see the Mouse which I understand should be at the bottom of the page just below the Command Line help advise required please.
Re: ver.3.21.3pro. unable to exit QCAD
Post by Husky » Wed Jan 30, 2019 8:25 pm
What is your Operation System?
nationalalf
Post by nationalalf » Wed Jan 30, 2019 8:32 pm
Win 10 pro.
nationalalf
Post by nationalalf » Wed Jan 30, 2019 8:39 pm
Thanks for your interest in my problem. I'm new to all of this (Forum) I 'm using a Win 10 pro. i3 16GB mem. GF 730card.
Post by Husky » Wed Jan 30, 2019 8:49 pm
One possibility could be that QCAD is in a Full screen mode. Try to toggle back witch the F11 key on your keyboard or use the Menu
nationalalf
Post by nationalalf » Wed Jan 30, 2019 9:39 pm
From across the pond, A Very Big Thank you problem solved.
Post by Husky » Wed Jan 30, 2019 9:44 pm
You're welcome. :wink:
