Bitmap overlays drawing
caigner
Post by caigner » Fri Oct 26, 2018 9:49 am
Hi!
I am using QCAD pro v3.21.3.0 on Linux. Works like a charm. :-)
First I created a drawing. Then I imported an image and scaled and moved it into position. So far, so good.
My problem is now that I can't see my drawing anymore. It is hidden underneath the image.
How can I make the drawing visible again, bring it to the foreground?
Christian
QCAD Pro on Gentoo Linux
TSG
Re: Bitmap overlays drawing
Post by TSG » Fri Oct 26, 2018 10:20 am
Hi Christian,
you have to bring your overlay in the foreground and then you can make it more or less transparent.
After selecting the overlay you'll find a slider "fade" in the Property Editor.
Thomas
Post by andrew » Fri Oct 26, 2018 10:37 am
First, I'd move the bitmap to the background (underlay):
- Select the bitmap (click close to border)
- Modify > Draw Order > Send to Back
Optionally, you might then want to make the bitmap transparent to make your drawing more visible:
- Select the bitmap
- Show property editor (View > Property Editor)
- Change property Fade to for example 50 for 50% or 75 for 75%, etc.
caigner
Post by caigner » Sat Oct 27, 2018 9:25 am
I didn't know about the Modify > Draw Order > Send to Back possibility! Every day you learn something new.
Thanks!
And also thanks for pointing me to the Fade-option.
