Saved Drawing Prints White
Jock
Post by Jock » Thu Mar 29, 2018 11:16 am
I am using QCAD Pro, I have saved the attached drawing and at the time didn't understand the message regarding printing as white. I have tried few things to change this, but can't seem to get it to print black. Can you advise me on this please.
Hardy Spicer.dxf
(138.73 KiB) Downloaded 96 times
Re: Saved Drawing Prints White
Post by Husky » Thu Mar 29, 2018 6:10 pm
Hi Jock - welcome to the QCAD Forum,
Jock wrote:... didn't understand the message regarding printing as white.
Please check and adjust first your Page size settings. Looks to me they are some kind of off ...
Post by CVH » Fri Jun 01, 2018 6:15 pm
A: Your drawing is on layer Defpoints this is a system layer.
B: Your drawing is in white that looks white on black in drawing mode and white on white in print preview mode
C: Your drawing is in inches and your paper too, measurement system is in metric
D: You are going to print on a 210 inches width and 297 inches high paper. Thats >5m by >7.5 meter
