Hello again, this time i wonder how can i create a hatch by using RHatchData and RHatchEntity. Let's assume i have created circle,
var circle = new RCircleEntity (document,new RCircleData (p11,1));
how can i fullfil this circle by using RHatchEntity. Is there any example script of this?
And secondly i also wonder calling this drawing from block to my current layer. How can i insert block to my layer by scripting. Cause i need to use one block multiple times.
Thanks a lot.
Hatch creation and calling it from block
Re: Hatch creation and calling it from block
Hi woddy
There is an example script called 'Wallchart-en.js' which creates a block with a hatch colour of mid grey and inserts it multiple times into the drawing. You can find it here. ('-en' is the English version).
viewtopic.php?f=107&t=2910
Note: You need to first define a hatch boundary to create the hatch. In your case the boundary would be the circle.
Hope this helps.
Regards
riverbuoy
Hope this helps.
Regards
riverbuoy
