[solved] Correct way to make this Arc
slyde
Post by slyde » Sun Dec 10, 2017 2:43 pm
Hi Forum:
I came across some CAD exercises the other day. Being new to CAD, this made me happy. But last night one of them got me. Last piece of the puzzle too! It was a 20 degrees radius arc. I tried all of the arc tools and cldnt make it work. What I ended up doing was making a 20 degrees radius circle and eyeballing it in place, then trimming it. And that's not the way to do it. But I can't figure out how to achieve this arc.
Here's a pic of the exercise, followed by what I did.
Screenshot from 2017-12-09 23-02-15.png (185.38 KiB) Viewed 1187 times
Screenshot from 2017-12-10 07-45-46.png (16.33 KiB) Viewed 1185 times
I'd appreciate someone showing me how to draw in this arc the right way. Thanks.
Slyde
ex-5.dxf
(117.64 KiB) Downloaded 54 times
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Clive
Moderator / Drawing Help
Re: Correct way to make this Arc
Post by Clive » Sun Dec 10, 2017 3:28 pm
2 Tangents and Radius
Always look and work with all the geometry information given, in this case circles.
Run the tool and choose the correct circle you need, then break out/trim to suit.
2 Tangents and Radius.jpg (52.99 KiB) Viewed 1181 times
slyde
Post by slyde » Sun Dec 10, 2017 3:49 pm
Thank you, Clive. Next cup of coffee's on me :-)
Screenshot from 2017-12-10 08-47-33.png (212.15 KiB) Viewed 1175 times
Slyde
Clive
Re: [solved] Correct way to make this Arc
Post by Clive » Sun Dec 10, 2017 4:05 pm
Thanks Slyde.
Try these when you have time.
EXERCISE 1.jpg (88.63 KiB) Viewed 1172 times
EXERCISE 2.jpg (111.38 KiB) Viewed 1172 times
EXERCISE 3.jpg (84.33 KiB) Viewed 1172 times
EXERCISE 4.jpg (118.48 KiB) Viewed 1172 times
