Hi Forum:
I was wondering if there's a better way to use the dimension tool so that I don't get these extended lines.
Without dimensioning:
With dimensioning:
Please advise. Thanks.
Slyde
OS: Linux M<int 18.3
QCAD Pro: 3.19.1.0
[solved] Is there a better way to do this?
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: Is there a better way to do this?
Not in the current version.slyde wrote:Hi Forum:
But you can fix that manually. Select the DIM and drag the Extension line back with help of the blue points ...
Thank you.
