Hello all,
Is there any way to print points like they look in model space? I use mode 2 (cross) to draw in model space, but I always print a dot in paper space. I would like to print a cross as well if possible.
Thanks! Best regards,
David
Point display in paper space
- dfriasb
- Senior Member
- Screenshot from 2017-11-24 15-33-35.png (35.4 KiB) Viewed 3929 times
Re: Point display in paper space
No, these are for display only (pixel sizes). If you need to print something else, I'd recommend using blocks.
- dfriasb
- Senior Member
Thanks for your super fast answer Andrew!
Yes, I'll do it with blocks.
Have a nice weekend,
David
David
