Print cut off
Print cut off
Post by andrew » Wed Aug 30, 2017 8:53 am
From a QCAD user:
When printing my drawing, some of the drawing is cut off. Do I have to move my drawing?
Re: Print cut off
Post by andrew » Wed Aug 30, 2017 8:55 am
No. You can simply move the paper around under your drawing using the tool "Move Paper Position" (paper and hand icon in options toolbar at the top):
Screen Shot 2017-08-30 at 09.54.20.png (18.82 KiB) Viewed 3165 times
Clive
Moderator
Re: Print cut off
Post by Clive » Wed Aug 30, 2017 9:19 pm
In addition....
if you have set the paper size you need - in most wanted cases big enough for the drawing! Then using the 'Auto Center' option will help as a first step and then as Andrew points out move the paper manually to suit if needed.
Auto Center.jpg (10.32 KiB) Viewed 3155 times
