cxf fonts
robjuda
cxf fonts
Post by robjuda » Mon May 29, 2017 4:09 pm
I learned that there are cxf fonts, but when I make a txt, only TT fonts are available..
How to use cxf fonts??
Re: cxf fonts
Post by andrew » Mon May 29, 2017 6:55 pm
You can find the CXF fonts at the top of every font selection box. For example "Standard".
ljbuller
Re: cxf fonts
Post by ljbuller » Thu Apr 25, 2019 4:18 pm
Only Standard comes up in my font listing and then all of the true type fonts.
If I try to open one of the cxf fonts (3.22.0) first of all the file filter does not have a choice for cxf fonts, If I choose all files and try to open, I get a "Cannot open file 'C:/Program Files/QCAD/fonts/GreekC.cxf'. No suitable Importer found. Please check file format and extension." message
in application preferences - draw - text, I have "check all" selected.
When I go to draw simple text and drop down the main font, all of the entries have the TT symbol which I take to mean true type.
So 2 questions.
1. How do I open a cxf file to edit
2. How do I select a csx file to draw?
Re: cxf fonts
Post by andrew » Thu Apr 25, 2019 6:59 pm
You can see what CXF fonts you have in the fonts directory of your QCAD installation (Standard, Greek*, Roman*, Italic*, Unicode, ...).
CXF fonts can be loaded and edited as drawings in the current snapshot release (3.22.0.8).
See also:
https://qcad.org/en/changelog
