how to use tool like trim or lengthen in scripting
Hi I am newbie here, I wonder how can I use tool like trim or lengthen in scripting, for example I have created a line in my script and I want to extend it in my script, how do I do that? thanks.
Re: how to use tool like trim or lengthen in scripting
trim and lengthen have been added to the QCAD Simple API:
http://www.qcad.org/doc/qcad/latest/dev ... imple.html
Example:
https://github.com/qcad/qcad/tree/master/scripts
Example:
var e1 = addLine(10,10,50,10) lengthen(e1, false, 10) var e2= addLine(30,30,40,20) trim(e1, 40,10, e2, 40,20, true)You can find the latest files of the QCAD Simple API at:
Thank Andrew for very helpful answer very appreciate it, I have another question How can I translate my drawing to any coordinate rather than (0,0) because I have two drawing one starting at (0,0) and another I want to offset to other coordination. Should I start both at (0,0) and then select and move another one to my specific coordination?
I'd probably create one or multiple off-screen documents (createOffScreenDocument) and paste them into the drawing at various locations / scales / rotations.
I've updated the simple API to make this as easy as possible:
// create an off-screen document: var doc = createOffScreenDocument(); // add entities to off-screen document: startTransaction(doc); addLine(...); addArc(...); endTransaction(); // paste off-screen document into current drawing document at 100,0, scale 1, no rotation: paste(doc, getDocumentInterface(), new RVector(100,0), 1.0, 0.0, false, false, false, false, false);You can find the updated simple scripts at:
Thanks you very much for helping me out
Hi Andrew,
When I create offscreen document and addLine to it, It works fine but when I try to use lengthen or trim like this:
var doc = createOffScreenDocument(); startTransaction(doc); var e1 = addLine(10,10,50,10); lengthen(e1, false, 10); endTransaction(); paste(doc, getDocumentInterface(), new RVector(100,0), 1.0, 0.0, false, false, false, false, false);I got error :
"TypeError: Result of expression 'entity' [undefined] is not an object."
Please update simple_modify.js
As you can see, the simple API is evolving ad-hoc. You are strongly encouraged to also suggest your own changes and additions and submit them through this forum or through github.com.
AddEntity() return undefined when use with offscreen document so I changed it to return entity now I can use trim and lengthen.
