From cad to cam to machine
iMac1943
Post by iMac1943 » Sat Feb 13, 2016 8:07 am
Can one go from QCAD to a CAM program (any suggestion for Mac?) and finaly to the computer on a cnc router?
Your advice please.
Re: From cad to cam to machine
Post by andrew » Mon Feb 15, 2016 10:53 am
Yes, that is how CAM typically works. The whole process depends a lot on your specific needs, but a typical use case would be:
- Create CAD drawing using CAD (output: DXF file).
- Generate program for computer controlled machine from CAD drawing (output: typically G-Code or similar).
- Load program into machine and process work piece.
iMac1943
Post by iMac1943 » Mon Feb 15, 2016 12:01 pm
Thank you Andrew, I started an other question here:
viewtopic.php?f=32&t=3991&p=14522#p14522
Can you see there what the question is and what the reply?
Luc
