Reference snap to ring, donut...
jancarel
Post by jancarel » Wed Oct 07, 2015 12:24 pm
I am using Qcad Pro 3.11, Linux 32bit. I am trying to create a printed circuit board layout. The newly added feature Draw-Ring is verry helpful. Using Snap Reference I can only snap to two points on the X axis. How can I snap to the two reference points on the Y axis?
Example of Snap-Reference to a Ring...
Thanks for your help,
Jan
P.S. Qcad Pro is a great program. Thank for the good work...
Re: Reference snap to ring, donut...
Post by Husky » Wed Oct 07, 2015 8:38 pm
Hi jancarel,
jancarel wrote:Using Snap Reference I can only snap to two points on the X axis.
This tool is also new to me but I have to confirm that your experience is correct. Snapping to the top or bottom Y Reference points is impossible without exploding the ring. :cry:
jancarel wrote:How can I snap to the two reference points on the Y axis?
If you create a new ring you can use the reference point option to place your Ring precisely to a x or y connections.
I think you should file a bug report / feature request in the QCAD bugtracker .... :wink:
Post by andrew » Wed Oct 07, 2015 9:09 pm
As you might have noticed, a ring is in fact a polyline with two vertices. The two reference points are the two vertices of the polyline. A possible solution could be to add reference points to all middle points of arcs as well.
jancarel
Post by jancarel » Thu Oct 08, 2015 5:06 pm
andrew wrote:As you might have noticed, a ring is in fact a polyline with two vertices. The two reference points are the two vertices of the polyline. A possible solution could be to add reference points to all middle points of arcs as well.
Thanks Andrew, this is the solution. Snap to endpoint for left/right and Snap to middle for top/bottom. This works well...
And thank you for Qcad, a great program...
Jan
Post by andrew » Thu Oct 08, 2015 5:17 pm
jancarel wrote:Snap to endpoint for left/right and Snap to middle for top/bottom.
Yes, that should work, good point. Auto snap should also work if it's configured to snap to end and middle points.
jancarel
Post by jancarel » Fri Oct 09, 2015 8:48 am
Hi Husky,
Thanks for your thoughts. Now that I know that the ring is made out of two halves, I can use Snap End for left/right and Snap Middle for top/bottom. This works fine. For me there is no need to file a Bug Report...
Jan
