Exoprt a high resolution image file?
astridoa
Post by astridoa » Wed Feb 04, 2015 8:25 am
How can I export a high resolution image file - apt for publication print - from QCAD pro?
I have tried through bitmap export, but the results are very low resolution!
I'd be very pleased by your help!
Re: Exoprt a high resolution image file?
Post by andrew » Wed Feb 04, 2015 10:00 am
- File > Bitmap Export...
- In the file dialog, choose the format (BMP, PNG, JPEG, TIFF, ...)
- In the bitmap export dialog, choose the desired image size or resolution in pixels per drawing unit:
Screen Shot 2015-02-04 at 09.38.11.png (36.66 KiB) Viewed 3006 times
Keep an eye on the width and height of the bitmap. Large values can potentially produce huge image files or even stop QCAD if it runs out of memory:
- 1'000 x 1'000 -> ~ 3MB
- 2'000 x 2'000 -> ~ 12MB
- 5'000 x 5'000 -> ~ 75MB
- 10'000 x 10'000 -> ~ 300MB
- 20'000 x 20'000 -> ~ 1.2GB (might fail)
- 100'000 x 100'000 -> ~ 30GB (will almost certainly fail!)
algrass
Re: Change default 640x480
Post by algrass » Thu Sep 03, 2015 4:38 pm
Is there a way to change the default 640x480 in the Bitmap Export dialog box to another one? I normally use 1920x1080 and would be desirable to set this new size as a default rather than entering it every time. Is there an xml file that can be modified?
