I have this block's inserted into a drawing.
On that drawing, clicking on anything belonging to this block reference selects the block, but...
(and it is an annoying but )
for some reason any infinite lines inside block reference are not selectable ....
Trimming this infinite/horizontal/vertical line inside a block, makes it selectable in the block reference again, but...
the usual scenarion is:
use infinite/vertical/horizontal inside a block
forget about it and go back to main drawing
sometime later you notice infinite line in the main drawing,
it is not selectable (it belongs to a block), so I can't check which block it belongs to...
now starts mad search through all the blocks (and I use them extensively) to find which one has the offending line
QCAD Professional
Version: 3.28.2.0 (3.28.2)
Internet: QCAD.org
Build Date: Aug 30 2023
Revision: a8039fc
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
