MAC OS Ventura 13.2.1
QCAD/CAM Pro 3.28.2
Novice user here. I suspect this is an easy answer but I cannot figure it out.
Say create a shape, a circle with defined diameter of 20 mm, entered in the command line. Later I want to change the diameter to 30 mm. When I select the circle I no longer get the command line option to change it. Is there a way to enable this ability?
Thanks,
Alan
Change shape attributes once created
- Screenshot 2024-02-26 at 7.54.14 PM.png (191.33 KiB) Viewed 516 times
Re: Change shape attributes once created
select the circle and within the Property Editor you can change the diameter to 30.
Got it. Thank you.
