(SOLVED)Simplify lay out of icons
Graham
Post by Graham » Sat Feb 17, 2024 6:15 pm
WIN 11
QCAD 3.29.4
HI ALL
I do not use a lot if the icons in the tool bars because most of my drawings are fairly
simple.
Is it possible to remove unused icons and store them in an off the screen tool bar or folder for just in case times?
Graham
Re: SIMPLIFY LAY OUT OF ICONS
Post by CVH » Sun Feb 18, 2024 1:46 am
It is possible to alter default Toolbars.
Or one can group some frequently used tools in two custom Toolbars with QCAD Pro.
Displaying certain Toolbars is configurable.
For visibility in default Toolbars or the custom Toolbars see:
Menu Edit .. Application Preferences .. General .. Tool Settings.
It are settings for each QCAD tool.
For the visibility of Toolbars see:
Menu View .. Toolbars and Widgets .. Toolbars
Graham
Post by Graham » Sun Feb 18, 2024 11:39 am
CVH thank you for your reply.
I will experiment and see what happens. Then report back if I can achieve what I want. Widgets are a whole new world to me
Graham
Graham
Re: Simplify lay out of icons
Post by Graham » Sun Feb 18, 2024 10:46 pm
Well I tried and found the experience not very intuitive.
Luckily I had made notes and was able to get back to where I started.
So my next question if you do not mind.
Can you get rid of all toolbars and run on menu only?
Graham
Post by CVH » Sun Feb 18, 2024 11:21 pm
Right-click on empty space in the menu bar.
Point at Toolbars or Widgets.
Turn off the Toolbars and Widgets by preference.
Also accessible under menu View .. Toolbars and Widgets
Graham
Post by Graham » Mon Feb 19, 2024 11:44 am
Managed to untick toolbar 1 & 2 then no more left to remove in widgets.
Is it possible to remove the others?
Or have I completely messed up?
Graham
Post by CVH » Mon Feb 19, 2024 2:53 pm
Left - Left = CAD Tools Toolbar
Top - Left = View Toolbar
Top - Right = File Toolbar
Top - Mid = Reset Toolbar :shock: :!: :?: (Usually Top-Left)
Second line - right = Widgets Toolbar :shock: :!: :?: (Usually vertical Right - Right)
Bottom - Bottom = Status Bar (via menu View or toggle by shortcut GS)
Graham
Post by Graham » Mon Feb 19, 2024 9:14 pm
Thank very much CVH !
I now have what I want and with the knowledge learned can build it from there if required.
Graham
