How to make Scale Options proportional by default
I'm using QCAD version 6.5.2; recently upgraded from 4.8.6.
OS is MacOS 14.1.2
On my older version of QCAD the scale option tool held the proportional feature as a default. Now I seem to need to click the chain link button each time I change scale, which is fiddly. Is there a way to make the proportional feature the default setting?
Many thanks
Féidhlim
OS is MacOS 14.1.2
Many thanks
Féidhlim
Re: How to make Scale Options proportional by default
This has been fixed for the next release:
https://qcad.org/en/changelog
FS#2525
Please note that there are no QCAD versions 6.5.2 or 4.8.6. Could this be the Qt version?
The current QCAD version is 3.29.3.
FS#2525
Thanks Andrew,
Ah, I see the two version entries now. It's QCAD Version 3.28.2.4 (3.28.2.4) in the recent upgrade; and my older version was 3.9.1.0 (3.9.1) which had a number of features which seemed to work more smoothly. (I actually liked the fact that the bitmap import button on the old version showed a colour photograph whereas the newer version is B&W, like something on a Canon camera display which doesn't have colour capability...)
The change proposed is as follows:
" FS#929 - Modify - Scale: Proportional scaling has no effect
If the keep proportions button is checked in the scale dialog, no scaling is performed."
What I am encountering is slightly different, insofar as when I check the proportion button I achieve what I want to achieve for that single action; but the newer CAD version won't keep that as a default operation, whereas the older version did.
Are we talking about the same thing? In which case, do you know what the timeframe is on such changes? Thanks
We cannot communicate a timeline for the next version as this depends on passing unit tests on all platforms. This is not considered a high priority issue.
I'm sure. Thanks for that and for your help with the upgraded version. Féidhlim
The button icon was indeed updated on Dec 12, 2018
Probably a Dark theme related update.
https://github.com/qcad/qcad/commit/a2b ... 9c64930347
And you can download the previous SVG from there.
It should be possible to customize button images.
https://www.qcad.org/rsforum/viewtopic. ... 653#p42653
Although I did not tested that (yet) for the default theme ...
Thanks for that.
QCAD 3.29.4 is now available which should fix this issue.
Thanks Andrew, I'll try that.
