Move origin
ganlanshu
Move origin
Post by ganlanshu » Mon Jan 08, 2024 9:25 am
Hello everybody.
I am familiar with Autocad LT and Draftsight but new to QCAD.
Is there a way to move the origin of the drawing (reference pont for all the coordinates) ? It is a feature I used very often with other software but I cannot find in the reference manual.
If not, is it planned for future versions ?
Thank you very much.
Ganlanshu
Re: Move origin
Post by CVH » Mon Jan 08, 2024 11:41 am
QCAD does not support an UCS at this point.
https://qcad.org/bugtracker/index.php?d ... ask_id=694
Instead of moving the drawing origin, one can move everything relative to the drawing origin.
Ensure that you are able to select everything before moving, thincking of locked, hidden or frozen layers, ...
For coordinate input one can lock the relative zero and use relative notation.
Absolute coordinates are always related to the (fixed) origin of the drawing.
