[solved] Drawing multi radius curves
- Registered Member
I am inexperienced with QCAD and have got stuck with making the attached drawing composed of 3 curves of 2 radii.
Could anyone show me how to get them even and connecting smoothly.
I am using QCAD version 3.25 on Windows 11.
Regards, Paul.
Regards, Paul.
- img045.jpg (200.58 KiB) Viewed 2905 times
- petevick
- Premier Member
Re: Drawing multi radius curves
I would think using Ellipse with radii or Ellipse with diameters would work for you - find them in the Draw>Ellipse menu
Pete Vickerstaff
Hi Paul Scott - welcome to the QCAD community.
... or this one?
There are different ways to solve this puzzle - what do you think about this approach ...Paul Scott wrote: ↑Mon May 29, 2023 7:54 pmCould anyone show me how to get them even and connecting smoothly.
... or this one?
Paul, "connecting smoothly" with arcs is called tangentially connected.
As you can see in Husky's GIF's that can be accomplished by trimmed roundings or with the tangent arc/circle methods and trimming.
There are more and better suited tangent circle methods but these require more and correct trimming.
What I miss in your sketch is the overall height but I think that you can manage to add a horizontal line at the proper place.
- petevick
- Premier Member
An ellipse can be constructed by using the concentric circle method, which is what I'm assuming the two commands I pointed use. The request was indeed asking for two radii, which is effectively what the concentric circle method uses.
Pete Vickerstaff
Not to my knowledge.
A concentric circle (CC/CG) is again a circle with the same center but with a different radius.
I can not create an ellipse using CC or CG.
There is nothing like concentric ellipses ... CC or CG based on an ellipse is a shape approximated by a spline.
Any circle has but one unique radius, there is nothing as a concentric circle with two radii.
Any of the ellipse methods creates an ellipse or ellipse arc.
The term radii is short to use as tool-tip but ambiguous, they are correctly called 'semi-major axis' and 'semi-minor axis'.
If the major axis is equal to the minor axis we get a special case what is circle or an arc.
The chances that an ellipse arc explode to 3 tangentially connected arcs with the required radii is second to none.
This may be going over what others have said, but here's the basic construction for what you're needing. It's not a pretty QCAD diagram, but it was simple enough to do with pencil and paper to help show what's going on with the fundamental geometry.
First off, draw your verticals 22mm apart, and decide where the centre for your top arc will be.
Next you can draw an arc with a radius of 18mm touching for the top curve.
Because the radius of the other smaller arcs are 4mm, and these have to touch both your top arc AND the sides, the centre of these circles must fulfil both these conditions:
1) be on a line parallel to your vertical lines. So draw a vertical line 4mm inside your main shape.
2) be 4mm away from your R18 curve, so 18mm - 4mm is 14mm. Draw an arc with the same centre as your R18 curve with an R18.
Where these intersect is the centres of your R4mm circles, and there will be no sharp change in curve between any of your lines. In fact, the point the curves join can be determined by drawing a line from the centre of your R18 and the centre of your R4 circles. Where this crosses the circles is the point of tangent.
If this hasn't been helpful, I hope it has been interesting.
Derek
Derek
QCAD Version 3.29.4 : Windows 10
Thank you Derek for the exact ruler-and-compass construction method.
We can replicate your sketch using construction lines in QCAD and deleting them afterwards
BTW, this is not how QCAD solves these puzzles using the tangent methods nor using the round method.
Meanwhile Husky has entered a feature request for a 2 tangent and radius arc tool ... With trimming if possible.
- Registered Member
Thank you to everyone who replied to my enquiry. I have tried the various methods suggested and successfully progressed by drawing.
Your ideas have been very instructive.
Paul.
Paul.
Just a quick follow up to something I picked up on early on in the post...
While Paul wasn't wanting an ellipse, I can understand how Pete thought he did, and there is a construction for an ellipse called the concentric circle method, which uses concentric circles which have diameters equal to the major and minor axes of the desired ellipse. It's also known as the auxiliary circle method, and is one of the quickest and simplest ways to draw an ellipse.
Cheers
Derek
