- Example Script.png (50.4 KiB) Viewed 1681 times
Example Scripts. How to observe source?
howto find and observe script's source?
Re: Example Scripts. How to observe source?
You can find them under scripts/Misc/Examples or online at:
https://github.com/qcad/qcad/tree/maste ... c/Examples
Got this!
function ExDeleteObject(guiAction) {
ModifyExamples.call(this, guiAction);
ExDeleteObject.prototype = new ModifyExamples();
ExDeleteObject.prototype.beginEvent = function() {
ModifyExamples.prototype.beginEvent.call(this);
var op, entity, id;
// add line entity,
// document takes ownership of entity:
op = new RAddObjectsOperation();
entity = new RLineEntity(document, new RLineData(new RVector(0,0), new RVector(100,100)));
op.addObject(entity);
di.applyOperation(op);
// after applying the operation, the ID of the newly added entity is known
// and can be stored as reference for the added entity:
id = entity.getId();
EAction.handleUserMessage(qsTr("Added line with ID %1".arg(id)));
// query a copy of the stored entity from the document
// and use it to delete the entity:
entity = document.queryEntity(id);
op = new RDeleteObjectsOperation();
op.deleteObject(entity);
EAction.handleUserMessage(qsTr("Deleted line with ID %1").arg(id));
EAction.handleUserMessage(qsTr("You can use <i>Edit > Undo</i> to restore the line entity."), false);
this.terminate();
* Adds a menu for this action.
ExDeleteObject.init = function(basePath) {
var action = new RGuiAction(qsTr("Add and Delete Line"), RMainWindowQt.getMainWindow());
action.setRequiresDocument(true);
action.setScriptFile(basePath + "/ExDeleteObject.js");
action.setGroupSortOrder(78200);
action.setSortOrder(100);
action.setWidgetNames(["ModifyExamplesMenu"]);
