[solved] Multiple size drawings
rluke
Post by rluke » Mon Jan 24, 2022 3:44 pm
Qcad Professional Trial
Windows 10 Home
Is it possible to make a template (with title blocks) that contains more than one size of drawing? I'd like to be able to print some portions of my model on standard 8 1/2" x 11" and also be able to have larger size drawings for a plotter.
Rich
Re: Multiple size drawings
Post by andrew » Mon Jan 24, 2022 3:46 pm
Yes, you would typically use layout blocks to prepare those different layouts:
https://www.qcad.org/en/tutorial-workin ... -viewports
rluke
Post by rluke » Tue Jan 25, 2022 2:17 am
Thanks Andrew
I'll mark this as "solved"
