Hi Q Artists,
I like to use colors in a drawing, both lines and coloring circles, triangles, squares etc.
Does anyone know of a good tutorial or tips to learn this.
Thanks in advance.
[solved] Colors
Re: Colors
in CAD it is common practice to organize entity attributes like color or line weight with layer. Set a layer up e.g. with the color red and assign every entity which has to be red to that layer etc. If you need to fill a shape like a rectangle or triangle with color you can use a solid hatch and assign it to the appropriated layer.
Here is a tutorial about working with layer:
https://qcad.org/en/tutorial-working-with-layers
- Junior Member
Re: Colors
Thank you Husky.
