can i change color grey to black?
version 3.26.4.0
windows 7can i change color outside print area in paper space?
Re: can i change color outside print area in paper space?
No. You can change the print area color but not the grey area. To change the paper background go to Edit > Drawing Preferences > Printing > Colors > Background Color.
thanks for reply. should i move this post to suggestion?
Sure - you can do that. But you would get a better chance if you fill a feature request below:
https://www.qcad.org/bugtracker
Note: The QCAD Forum login will not work there - you need to register again to get access.
