(solved) how to connect multiple lines
kharn.duffy
Post by kharn.duffy » Thu May 13, 2021 2:24 am
im just wondering and its probably right in front of me. but how do you connect all lines you have selected to make one whole line?
so say you make a square out of individual lines trim the corners and select each line, is there a way to join them all to make it one?
cheers
Re: how to connect multiple lines
Post by Husky » Thu May 13, 2021 3:03 am
... is there a way to join them all to make it one?
Yes, that would be a polyline and there are multiple ways to do that.
One could be: Select your lines and launch the tool "Polyline from Selection" (CE). It will convert the selected and connected lines to a polyline ... :wink:
Post by CVH » Thu May 13, 2021 5:17 am
That would be (OC) If I am not mistaken.
(Unless one has customized the tool shortcuts.)
Always trim before you use "Polyline from Selection" (OC).
Read more here:
viewtopic.php?f=32&t=8412
Post by Husky » Thu May 13, 2021 7:04 am
Correct. Thanks for the clarification.
Read more here:
Please don't confuse user with unrelated topic cross-references. So far the issue / goal description from the user is clear and there is no need for an baseless "Always trim" advise for the "Polyline from Selection" tool.
Post by CVH » Thu May 13, 2021 7:44 am
From my point of view: Not unrelated.
If not trimmed proper and having gaps/overshoots the original entities may rotate/slant a tiny bit.
Simply a sound advice on good partice.
