Keyboard Shortcut for Undo Last Point While Drawing Splines
BrianZ111
Post by BrianZ111 » Sun Feb 05, 2023 9:29 pm
Can a keyboard shortcut be set for undoing the last fit point (or control point) while drawing splines? I've looked under Application Preferences > General > Tool Settings but I can't find it in there so putting this under suggestions. If it is already possible, please let me know how. Thanks.
Re: Keyboard Shortcut for Undo Last Point While Drawing Splines
Post by CVH » Mon Feb 06, 2023 12:44 am
There is an Undo Last Fit/Control Point button on the Options Toolbar.
But there is no method to add a shortcut to every Options Toolbar button.
Backspace would be a nice candidate for Splines and Polylines but for the moment it is reserved for deleting entities.
For the record: The single letter commands with LI and PL are not shortcuts but they work via the Command Line.
This could also be implemented for Splines.
Maybe you could add a feature request on QCAD bugtracker:
https://www.ribbonsoft.com/bugtracker/
You need to have a separate account there or register for a new one.
BrianZ111
Post by BrianZ111 » Thu Feb 09, 2023 8:36 pm
Thanks CVH and thanks Damon52 for offering to add it to the bug tracker. I didn't see anything in there yet though so I've gone ahead a created an account myself and added a feature request.
