Feature request: extending dimension line beyond extension line when using tick marks
sancyk
Post by sancyk » Sun Jan 22, 2023 11:27 am
QCAD Pro 3.26
I would like the ability to extend dimension lines beyond the extension line when using tick marks, so that the dimension looks like this
instead of this
Re: Feature request: extending dimension line beyond extension line when using tick marks
Post by CVH » Sun Jan 22, 2023 12:23 pm
Duplicate from:
https://www.qcad.org/rsforum/viewtopic.php?f=32&t=9784
sancyk,
This forum is more a place to debate about such things.
Suggestions may or may not be picked up by the developer, see it as a forest with many trees in it.
A more appropriate place to request for a feature is still QCAD Bugtracker:
https://www.ribbonsoft.com/bugtracker/
You need to have or create a separate account there. :wink:
Add a new task and select Feature Request as Task Type.
You could include a link to the QCAD 'How Do I' Questions topic.
And you could re-link the bugtracker entry over here.
sancyk
Post by sancyk » Sun Jan 22, 2023 1:36 pm
Got it! I had tried in the bugtracker as you had suggested but could not find how to post a new feature request.
sancyk
Post by sancyk » Sun Jan 22, 2023 1:49 pm
Submitted as a feature request in bug tracker
