Translation typo for Misc-Block-Export Block References List
Post by CVH » Wed Oct 05, 2022 6:48 am
Andrew,
QCAD Pro 3.27.6.0 Win 7 32 bit
I presume that this is BlockRefExport.js
The untranslated string is then "&Export Block References List".
But it seems to get translated into German.
The untranslated title for the save as dialog should be "Export Block References List (CSV)" but it is simply "Save As".
I use the system file dialog. :wink:
Re: Translation typo for Misc-Block-Export Block References List
Post by andrew » Wed Oct 05, 2022 7:37 am
Indeed, thanks.
