Is it possible to program the radio buttons in a dialog box on "double click" to: 1. select the option; and 2. close the dialog box.
This would speed production by saving the few seconds it takes to click the radio button, then move the pointer to OK and click OK.
Double Click Radio Button to Select Option and Close Dialog
- petevick
- Premier Member
Re: Double Click Radio Button to Select Option and Close Dialog
Speaking as an amateur Pascal programmer, as far as I know the radio button control does not support an OnDblclick event, it really goes against how the control is used, indeed, there are not many controls at all (in Pascal) that support a double click event. In Unix based OS's, double clicking is not as common as it is in Windows. Qcad is QT based, and I've no reason to doubt that it's radio button control would not support double clicking.
Hopefully for you, Andrew will prove all my drivel incorrect
Pete Vickerstaff
