Exception occurred. Entity NOT saved: XYZ
crowhurst
Re: Exception occurred. Entity NOT saved: XYZ
Post by crowhurst » Wed Dec 27, 2023 10:18 am
CVH, I detected one as Text in the Property Editor, but then I loaded a drawing from months ago on a separate project, and paste failed completely. I therefore took the nuclear option reset my configuration as you suggested, and so far all is working correctly. Many thanks for your time and expertise.
Nick
Post by CVH » Wed Dec 27, 2023 10:34 am
To my knowledge it is the second time odd behavior is fixed with trashing the preferences stored in QCAD.ini/config ...
Knowing what is stored there in textual notation does not explain odd behavior.
It could hardly be paste scale zero or empty because that won't paste anything.
I hope for you that the weird issues you had with QCAD are fixed. :wink:
Kind regards,
seadrill
Post by seadrill » Sun Feb 11, 2024 7:59 pm
When it comes to errors stemming from the OpenDesign libraries, resorting to manual intervention becomes the last line of defense. These libraries have a strict policy of saving only strictly standard data to DXF/DWG formats. However, the reality is that there are numerous files out there containing non-standard data. This is precisely when you're likely to encounter this particular error.
Ideally, all these discrepancies will eventually be smoothed out. But for now, navigating through this terrain involves a fair amount of trial and error. It's a matter of deciphering what data is deemed acceptable and what falls outside the realm of standardization.
