would it be possible to extend the tool for importing points with a label so that when importing points into the drawing (as it is now), the attributes of the point are taken from the csv file and written to the point's own properties? See attachment. This would extend the functionality of the tool and I assume that it would also lay the foundation for the possible re-export of such points from the drawing to a csv file, including all the details. Thank you for your helpfulness.
Tomek.
[solved] Import Points with Labels - add properties to the point
- QCAD_AttribPoints.PNG (98.11 KiB) Viewed 5958 times
QCADpro 3.26.4.7 / Win10pro 64 bit and FedoraWorkstation_32 64 bit
Re: Import Points with Labels - add properties to the point
Tomek,
You can always file a feature request here:
https://www.ribbonsoft.com/bugtracker/
I like your proposal, I'll vote for it.
Re: [solved] Import Points with Labels - add properties to the point
Thanks for the tip. I added a feature request to the bugtracker.
Tomek.
Tomek.
