label precision (SOLVED)
bambuko
Senior Member
Post by bambuko » Thu Aug 26, 2021 12:13 pm
as per thread:
https://qcad.org/rsforum/viewtopic.php?f=32&t=8698
It is sometimes (fairly often in my case) desirable to be able to change label precision setting for an individual dimension,
leaving all the other dimensions as set globally.
At the moment afaik it is not possible to do it in properties?
Can I, please, suggest this as an enhancement for future?
QCad Pro
Linux MX-21.3 "Wildflower"
Re: label precision
Post by andrew » Thu Sep 22, 2022 11:45 am
This is now possible in the property editor (since QCAD version 3.27.0, 2021/12/01).
