I really like QCAD.
However one thing that annoys me is that if I have the mouse over a drop down box and inadvertently move the scroll wheel the contents in the drop down box change. So I have to be awake while working near drop down boxes.
Drop Down Boxes
Drop Down Boxes
seasdes
QCAD Pro V3.27.8
User since 2021
W10
QCAD Pro V3.27.8
User since 2021
W10
- ryancousins
- Premier Member
Re: Drop Down Boxes
I was JUST thinking the same thing. When I go into Application Settings I always have to be careful not to change drop-down values! I just did it a few seconds ago and had to hit cancel and then go back in because it happened so fast I didn't get a look at what the original value was in the field I inadvertently changed.
