[{SOLVED] Standard library item 'Sink' broken
Post by CVH » Mon Nov 09, 2020 5:39 am
QCADpro 3.25.2.1 / win7pro 32 bit
The library item 'Sink' looks broken ...
TSG
Re: Standard library item 'Sink' broken
Post by TSG » Mon Nov 09, 2020 3:35 pm
No, it doesn't.
sink.dxf
(15.21 KiB) Downloaded 432 times
Post by CVH » Mon Nov 09, 2020 4:47 pm
Thanks to check :wink:
What version have you running?
Double-clicked on the link of your dxf file.
First got this:
  • Opening drawing: C:\Users\Admin\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\5C1XQV8Y\sink.dxf...
    Recovering file: C:\Users\Admin\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\5C1XQV8Y\sink.dxf...
    Recovery complete
    Drawing loaded successfully: C:\Users\Admin\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\5C1XQV8Y\sink.dxf
    Format: R24 (2010) DXF Drawing (OpenDesign) (*.dxf)
I didn't trust that one, so I downloaded the file for safety. :roll:
After a QCAD reboot I get the same warning and both times it looks like this one:
Doesn't look OK at my side ...
Yet another wipe and reinstall is lurking already. :?
Still very nice of you that you tested it. :P
Post by CVH » Tue Nov 10, 2020 9:34 am
Wondering...
Does anyone get the same errors as me with the file that TSG-Thomas posted?
Rantanplan7
Senior Member
Post by Rantanplan7 » Tue Nov 10, 2020 9:44 am
Hi CVH,
it looks broken on my system too.
For whatever reason - not important for me but a bit strange that there are users where it looks ok.
Best Regards
Sven
(former Autosketch 10 user)
TSG
Post by TSG » Tue Nov 10, 2020 10:02 am
I have to say, I'm working with QCAD 3.25.2.2 under macOS.
Maybe it's different. It wouldn't be the first time.
Thomas
TSG
Post by TSG » Tue Nov 10, 2020 10:15 am
It gets even better.
When I call the library "Archtecture" under Windows, a message "Recovering file: C: / Program Files ..." appears and the recovered sink.dwg is displayed incorrectly.
Everything works fine under macOS. No discovery, no misrepresentation.
Thomas
Post by andrew » Tue Nov 10, 2020 10:16 am
It looks correct here on:
- Win32, regular and legacy (XP)
- Win64
- QCAD 3.25.2.2 as well as QCAD 3.25.2.1
I did notice that the file was created using an older version of dxflib. This could be an OpenDesign bug or inconsistency if certain information is missing in the file. I've rewritten the file using OpenDesign and a newer dxflib and attached it. Perhaps you can test these on your systems.
sink_opendesign.dxf
(105.5 KiB) Downloaded 426 times
sink_dxflib.dxf
(29.64 KiB) Downloaded 449 times
TSG
Post by TSG » Tue Nov 10, 2020 10:34 am
Both work fine here under macOS AND Windows 10.
Thomas
Post by CVH » Tue Nov 10, 2020 10:53 am
Confirmed :wink:
No errors while loading, od=R27, lib=R15, both look OK.
Rantanplan7
Senior Member
Post by Rantanplan7 » Tue Nov 10, 2020 12:02 pm
Same on my system. Both ok now.
Best Regards
Sven
SOLVED: Standard library item 'Sink' broken
Post by CVH » Thu Dec 10, 2020 7:38 am
Solved in 3.25.2.4
