edit block in place
jim78b
edit block in place
Post by jim78b » Tue Oct 27, 2020 3:02 pm
Please add in future the function to edit blocks in place like autocad, thanks
Re: edit block in place
Post by CVH » Tue Oct 27, 2020 4:11 pm
Double click the block entity to edit the block itself ...
... what should be the purpose to edit a block in situ?
jim78b
Post by jim78b » Sat Oct 31, 2020 1:23 pm
It is very useful edit block in place .because in my work i can see outside the block and have referements.all cad have this feature .
Post by CVH » Sat Oct 31, 2020 1:45 pm
Jim78b, you probably do this already ...
Just to link the topics. :wink:
Workaround here:
https://qcad.org/rsforum/viewtopic.php? ... 721#p30042
jim78b
Post by jim78b » Tue Nov 03, 2020 9:36 am
yes i know but is annoying....
cccplex
Post by cccplex » Sat Nov 14, 2020 10:41 am
This was also on top of my feature request list. Luckily it got implemented now. :) https://www.qcad.org/bugtracker/index.p ... sk_id=1218
I think your feedback reminded Andrew this request from 2015 was still there. :P
15.6 GiB memory - i7-9750H CPU @ 2.60GHz - GeForce GTX 1650 - Latest Ubuntu
Post by andrew » Sun Nov 15, 2020 8:18 pm
It was more the suggested workaround that gave me the right idea on how this could be implemented relatively easily (explode and re-block). I have to admit that this can be quite useful in many situations.
cls77
Post by cls77 » Mon Nov 16, 2020 8:02 am
thanks Andrew, in which version is implemented this new feature?
Post by CVH » Mon Nov 16, 2020 9:34 am
The power of many thinking out loud.
Thanks.
Post by andrew » Mon Nov 16, 2020 10:37 am
This will likely be included in the next release (snapshot release).
cls77
Post by cls77 » Mon Nov 16, 2020 10:51 am
thank you very much
Post by andrew » Wed Nov 18, 2020 5:55 pm
Snapshot 3.25.2.4 with experimental support for in-place block editing is now available.
Reason: s/not/now/
petevick
Post by petevick » Wed Nov 18, 2020 6:07 pm
Snapshot 3.25.2.4 with experimental support for in-place block editing is not available.
'not' or 'now' Andrew :?:
Pete Vickerstaff
Post by andrew » Wed Nov 18, 2020 6:13 pm
'now', sorry.
ryancousins
Post by ryancousins » Thu Dec 10, 2020 2:13 am
Just downloaded the latest snapshot to check this out. Very awesome! I can imagine this being very helpful when making changes to a block relative to nearby geometry. Thanks!
