[SOLVED] Ruler measurement error
JohnRob
Post by JohnRob » Fri Oct 09, 2020 4:10 am
I have a architectural mode drawing where the ruler measurement give conflicting results.
My menu selection is:
Ruler / point to point / on entity.
the shorter distance is measuring 3 1/4" (correct)
a parallel line which should be further away is measuring 2' 11 11/16 (way wrong)
I have the grid at 1/8 inch (if it matters).
BTW the rectangle , triangle and circle were to be used in a description then I decided screenshots were better.
John
2 11-16.jpg (183.89 KiB) Viewed 6118 times
3.25 inches.jpg (175.16 KiB) Viewed 6118 times
Versions
QCAD version: 3.25.2.0
Date: Sep 4 2020
Qt version: 5.13.2
Compiler version: MSVC++ 14.0 (2015)
Build date: Sep 4 2020
Revision: 4a61501492c20734be6975d8e22c78667e7898af
Architecture: x86_64
Device pixel ratio: 1
OS: Windows
OS version: 10
Locale
QCAD locale: en
Country: 225
Country name: United States
Language: 31
Language name: English
Script: 0
Script name: Default
Decimal point: 46
Negative sign: 45
Positive sign: 43
Text direction: 0
System codec: System
Measurement Error.dxf
(150.08 KiB) Downloaded 372 times
Re: Ruler measurement error
Post by Husky » Fri Oct 09, 2020 6:05 am
The very left vertical line has 3D information (Y). QCAD is a 2D application and not capable to handle 3D.
To get rid of the 3D information try Menu / Misc / Modify / Flatten drawing to 2D and try again ... :wink:
JohnRob
Post by JohnRob » Fri Oct 09, 2020 4:50 pm
Thank you :)
That leads to two questions:
1) How might 3d information have been created? I imported the partially complete drawing from AudoCad Lite I think R12
2) Is there a way to tell if there is Z axis info?
John
Post by Husky » Fri Oct 09, 2020 5:48 pm
1. Yes, most of the time the drawing was used and saved in a 3D program. dxf version like R12 shouldn't matter ...
2. The QCAD property editor provides an option to show 3D values for Y. To find those entities it is like searching for a needle in a haystack ... :(
