"dist" command in addition to "infodist"
mtoiv
Post by mtoiv » Mon Aug 10, 2020 1:04 pm
Would it be possible to get a "dist" command that would do the same as "infodist" command?
It would be faster to use, if there would be an additional command to the "infodist" command.
Or is there any way to rename commands in the current Pro version of QCAD?
Re: "dist" command in addition to "infodist"
Post by andrew » Mon Aug 10, 2020 1:18 pm
If I understand you correctly, you want to use the infodist (Info > Distance Point to Point) command without having to type "infodist". Please correct me if I'm wrong.
You can set up your own commands under
Edit > Application Preferences > General > Tool Settings
Or you could use the very efficient two letter shortcuts ("IP" for this tool):
https://qcad.org/archives/shortcuts/shortcuts_en.pdf
petevick
Post by petevick » Mon Aug 10, 2020 2:38 pm
...or just type ip
Pete Vickerstaff
mtoiv
Post by mtoiv » Thu Aug 13, 2020 10:31 am
Thank you, the command ip is fine. Faster to use.
petevick
Post by petevick » Thu Aug 13, 2020 10:40 am
Sorry Andrew, I didn't see this when I posted my reply :oops:
Pete Vickerstaff
