Theming in Linux/ Ubuntu
manuvarkey
Post by manuvarkey » Sun Mar 29, 2020 8:20 pm
Recently purchased QCAD Professional. Earlier versions of QCAD used to respect theme under the Linux DE. The latest version do not respect the DE theme. I am overcoming this issue by adding a stylesheet.css under Themes/Default folder (Saw this path when running QCAD from command line and tried adding a file there. It seems to work.). Please come up with a solution in the coming updates.
