[solved]Layer state widget
ryancousins
Post by ryancousins » Fri Mar 27, 2020 10:32 pm
I don't see a layer state widget. I know I can use y1,y2, etc. But I was wondering if there was a way to see them in a list like you can with blocks, views, and layers, besides seeing them listed in the Layer menubar.
Re: Layer state widget
Post by Husky » Fri Mar 27, 2020 11:26 pm
There is no layer state widget in the current QCAD version 3.24.3.0.
TSG
Re: [solved]Layer state widget
Post by TSG » Sat Mar 28, 2020 10:04 am
So far, layer status has only been implemented very rudimentarily.
I wish something like a dialog box in which you can choose for each layer status, which layers belong to it and which not.
Feature Request under https://qcad.org/bugtracker/index.php?d ... sk_id=2060
rluke
Post by rluke » Sun Apr 03, 2022 12:11 am
Ryan
I think a wdget for layer states would be a great idea. Or at least have the option of displaying the current layer state somewhere on the screen.
Rich
