Can I set z-position to 0 (see attached Properties.png) with dwg2pdf tool?
Cause: I have a lot of drawnings that are a 2d project but for some reason it's have some entities with "z position" property with non zero value, then, when we convert it to pdf, the result is as attached pdf.
Best regards,
Rhodolfo Novochadlo.
[SOLVED] Set "z position" property using dwg2pdf
- Junior Member
- Properties.PNG (13.14 KiB) Viewed 7758 times
- CAD1.pdf
- (62.78 KiB) Downloaded 452 times
- CAD1.dwg
- (60.5 KiB) Downloaded 449 times
Re: Set "z position" property using dwg2pdf
to my knowledge the dwg2pdf script has not an option to flatten 3D drawings.
If I take your example dwg then I can use the Menu/Misc/Modify/"Flatten drawing to 2D" tool successfully flatten the drawing but that makes not really sense with a bunch of drawings ...
- Junior Member
Hello Husky,
Thanks for your quickly reply.
Is it possible develop a switch "Flatten drawing to 2D" to add to script dwg2pdf?
Really we have a lot of drawnings that we need to convert to pdf and is impraticable do this manually.
Best Regards,
Best Regards,
Rhodolfo: What are the exact parameters you are using when running dwg2pdf? I cannot reproduce this behaviour here with:
./dwg2pdf -l -a -f CAD1.dwg
- Junior Member
Hello Andrew,
Best Regards,
dwg2pdf.bat -a -c -d -f -n -l -w 0.1 -ltscale=1 -fs romans standard -fs romand standard -o "C:\temp\TesteDobra\CAD1.pdf" "C:\temp\TesteDobra\CAD1.dwg"
Can you try this with the latest development snapshot 3.23.0.5? Snapshots are available in the "Snapshots" folder on your download page. Thanks.
- Junior Member
Hello Andrew,
The problem was solved with version 3.23.0.5.
Thank you very much.
Best regards,
Best regards,
