Is it specific to 3.23.0.0 on macOS there are glitches left when D2
I drew a full circle in layer "new" and did a D2 on the lower half circle. As a result a white (layer "new") spot, length 0.000106 remains. Will be detected by "find zero lengths".
- Bildschirmfoto 2019-09-29 um 18.56.07.png (9.71 KiB) Viewed 10669 times
Christoph
Christoph
Re: Is it specific to 3.23.0.0 on macOS there are glitches left when D2
Till now I can't reproduce that. Please attache the dxf drawing. Thanks
Open a new drawing
draw a circle center point 0;0, radius 1.2
draw an infinitesimal horizontal line through center and right reference
add a second layer1, color orange, activate this layer
draw a vertical infinitesimal line through center of the circle
activate layer 0
select D2 and break out upper orange beam
break out piece within circumference
activate layer 0
- Zero_glitch.dxf
- (99.18 KiB) Downloaded 502 times
- Bildschirmfoto 2019-09-30 um 09.16.22.png (106.34 KiB) Viewed 10647 times
- Bildschirmfoto 2019-09-30 um 09.20.11.png (99.82 KiB) Viewed 10647 times
Christoph
Christoph
Not confirmed, please attach dxf.
It is attached.
BTW, I tried it out with day time theme, (opposite of dark theme) because I had problem with other program in conjunction with dark theme but it is not the case here.
Would be glad if someone could confirm it.
Christoph
Christoph
Can't confirm, please attach file before D2
- Zero_glitch_before_d2.dxf
- (99.71 KiB) Downloaded 496 times
Christoph
Christoph
Noop,
running WINpro7-32bit
Qcad 3.23.0.0 pro
Build Date:
Jul 18 2019
Revision:
42e52bf
Qcad 3.23.0.0 pro
Build Date:
Jul 18 2019
Revision:
42e52bf
Same reproducable erroneous behavior on Windows 10 x64 QCad 3 .23.0.0. So it's probably not a macOS/Mac Qt issue.
Christoph
Christoph
Reproducible - thanks for extra explanations.
In my opinion it makes no sense to use D2 twice in this situation. Please show us a screenshot what you try to accomplish within this task.
Oh I see, twice D2.
Confirmed, without testing.
That are two known ways to produce a Null-Length Entity.
Doubtful terrein....
Might be 'Intended Behaviour'....
Have issued many debates on this.
The first D2 cuts out a 90 degree Arc or a line piece.
From intersection to intersection, NOT including these endpoints.
The endpoints have to remain for the leftover arc/line(s)
Rest 270 degrees. Rest 1-2 line pieces
The second cuts out the other side 90 degree. Line piece.
Again:
Remains a Null-Length Entity.
An Arc with center, radius, sweep zero.
A Line with start = end, length zero.
Mathematically speaking nothing wrong with that.
Null-Length Entities have their mathematical meaning.
We still can elongate such an entity.
You all would probably know by now:
I will be the advocate to not produce unnessecary Null-Length Entities.
Besides Null-Length, real Null-Entities should be avoided at any cost.
These have totally no meaning as drawing entities and may let Qcad crash.
IMHO:
The trimming code should catch leaving a Null-Length as result.
Again:
IMHO:
Ok, you found a debatable glitch, you are right.
But, lets come back to the drawing.
You have a Horizontal edge.
You have a or several vertical orange XLine as constructor on a seperate layer.
> Default width would look nice here.
You drew a circle with center and radius at the intersection.
Fine, lets say all the circles...
Now you will start with trimming several half circles away.
Do the construction lines bother you every trim?
Wy not turning of the construction layer?
D2 tick, tick, tick, tick.
Husky had this moto: Work smart, not hard.
@Krischu
The issue is real and I would consider it as a bug.
It is not related to the current QCAD Version, OS or theme.
It occurs only if that named tool is used in a similar situation like this one within infinitive or ray lines. It will have Zero length entities as "leftover".
If I precede the same steps and tools on a situation with finite lines it will just work as expected. NO unwanted "leftover" produced.
I would encourage you to file a bug report below https://www.qcad.org/bugtracker
Ok, here are my findings:
