Trivial typos .js & site
Post by CVH » Thu Sep 26, 2019 11:24 am
Andrew,
expanding Flexpainter to handle polylines
I found two other trivial typos.
simple_create.js line 242
Two closing square brackets
simple_create.js line 243
Also a closing square brackets in extra after rel3
These are also reflected as such on the site.
https://www.ribbonsoft.com/doc/qcad/3.0 ... 50dba8ef67
Re: Trivial typos .js & site
Post by andrew » Mon Sep 30, 2019 9:56 am
Thanks.
Post by CVH » Mon Sep 30, 2019 10:06 am
Correction example 4 needs an extra Bracket in front.
But even then I can't get it to run.
Still busy in finding a solution.
Will start a new topic on that.
