Visibilty eye off doesn't care when zooming in
Krischu
Post by Krischu » Mon Sep 23, 2019 9:30 am
I have put some entities in a different layer. When I switch off the visibility eye for that layer in zoomed out state that layer is invisible as expected. But when I zoom in at some point the lines of that layer suddenly are appearing (although they are switched off for visibility) Is this a bug or a feature or a peculiarity of that macOS version?
Christoph
Re: Visibilty eye off doesn't care when zooming in
Post by andrew » Mon Sep 23, 2019 9:37 am
Likely a bug in the current snapshot release 3.23.0.2 you are using.
Note: Snapshots are packages with the current development version of QCAD. Snapshots should be considered unstable and are not intended for production use.
Krischu
Post by Krischu » Mon Sep 23, 2019 10:06 am
OK. I reverted back to 3.23.0.0 Pro, the official latest release.
Christoph
